Rocker Arm popped off!!!
Recently i installed a rebuilt engine in my 96 z28. When I first put it in the engine ran great. about 50 miles on the motor later it developed this hideous miss. well i checked all the plug wires and they were fione so I moved to thinking I had a stuck valve or something. well I pull the valve cover from the engine today and it turns out the rocker arm on the #8 cylinder exhaust had come completly off the valve. it is still bolted on but just turned sideways. the rocker appears fine and the pushrod is not damaged but i was womdering where to go from here.
Should i put the rocker back on and set the lash and hope it works or what?
Ed
Ed
Originally posted by eds96ragtop
Stock rockers........
I did not tighten them the engine came pre assembled.
Ed
Ed
Hopefully nothing broke but you won't know until you try to put it back together., that's what I would do. If you fragged something you sure would have had a lot more problems by now. Re-install it and see if she makes any noise. When I had a rocker get loose several years ago I definitely could hear it.
Hope this helps,
-Christian
Hope this helps,
-Christian
Brandon Wittmer
12-07-2014 12:15 PM
