Rocker Arm question
Rocker Arm question
I'm looking at the Comp Cams pro magnum rockers and the regular Magnum rockers. Im using a cc306 cam.
Are the pro mags going to make that much of a difference that I should pay an extra $100+ for them?
Re: Rocker Arm question
Not sure if the magnums will clear the springs you are using. Just a thought. As far as durability, the Pro-magnums can be rebuilt, the magnums cannot. It's $100, and in the long run you won't miss it. The Pro-magnums(full roller) were what I chose, and I was seriously considering the magnums(roller tipped) as well.
Dan
Dan
Brandon Wittmer
12-07-2014 12:15 PM
newby
07-25-2002 03:22 PM
