Rocker Arm Studs
Rocker Arm Studs
I'm currently running a stock shortblock with CNC Heads. Existing RR's are Comp Cams with 3/8" ARP studs. I'm looking to rebuild the engine as a 383. At what point does an upgrade to 7/16" studs from 3/8" become necessary? Is this dictated more by RPM or by cam lift? BTW, the cam I'm looking at running has a .570 lift with 1.6 RRs. I'd rather not spend extra money unnecessarily. Thanks.
Re: Rocker Arm Studs
IMO, 7/16 studs belong on anything with 120+ lbs of spring (seat) pressure. Unless you like giving up a bit of your lift to stud flex I'd go ahead and bite that bullet.
-Mindgame
-Mindgame
