rocker arms first, then cam later questions... and 224/230 or 230/236?????
#16
Originally posted by Z95m6
I believe a 112 will make more power. My friend has a post in the advanced tech and they are telling him for max power go with the 224/230 on a 110. The post is duration vs lift vs power or something you will see it the thread starter is turbo_Z
but if your goal is spray then 112 is low as i would go. mine goals are N/A so thats why im going to go 108 possibly a 109. but cam surge is a worry for me.
#17
Mine is on a 112 and it's noticeable at idle, but nothing horrendous since it's set at 850. When I'm running the ORP instead of the cat it sounds even better (1 ¾" midlength headers, 3" cat back, straight flow through type muffler).
#18
Maybe I could compromise and get it ground on a 113* LSA?
And would I want the XL or HL grind?
NCC-224HL
HIGH ENERGY
Comp Cams 224HL Camshaft 224/230 duration @ .050", .525"/.560" lift with 1.5 rockers, .560"/598" lift with 1.6 rockers. Excellent cam for 350 naturally aspirated cars, street/strip.
-----OR-----
NCC-224XL
XTREME
Comp Cams 224XL Camshaft 224/230 duration @ .050", .503"/.510" lift with 1.5 rockers, .536"/.544" lift with 1.6 rockers. Almost as powerful as the XH but easier on the valvetrain.
I am pretty sure the 224 XH is too much, as far as being too much lift and too radical for the valvetrain.
NCC-224HL
HIGH ENERGY
-----OR-----
NCC-224XL
XTREME
#20
NCC-224HL
HIGH ENERGY
-----OR-----
NCC-224XL
XTREME
NCC-224HL
HIGH ENERGY
-----OR-----
NCC-224XL
XTREME
this cam would be fine also for running nitrous even though its ground on a 112 LSA. the overlap is identical to that of the cc305(114 lsa) which a lot of guys use for nitrous.
#21
Thanks for the help guys. Right now I'm checking around to see if anyone will install this stuff for me.
No luck yet, and running out of places to go. I may just wait till summer and tackle it myself
#22
Originally posted by Shawn 97 Z28 M6
I had a 224/236 on stock heads and ran 12.5's, best of a 12.3.... Though I do have a 6 speed.
Damn I love being stubborn
Brandon Wittmer
12-07-2014 12:15 PM
