Rockers hitting stud
Old 09-05-2011, 09:09 PM
  #16
Bersaglieri's Avatar
Re: Rockers hitting stud
How about some pictures of the rockers and where they touch?
This is one reason I don't like aluminum rockers they must always have more material than an alloy or stainless steel rocker. Because of that, many times they are bulky and cause clearance issues, especially the ones that use lower grade aluminum.
Ocala: Nice car BTW.
-Dustin-
Bersaglieri is offline
Old 09-06-2011, 06:42 PM
  #17
Ocala93TA's Avatar
-Dustin-
Here is a pic , not all have this same marking but i would say atleast half .
Nice Car BTW Thanks Dustin
Ocala93TA is offline
Old 09-06-2011, 08:08 PM
  #18
ACE1252's Avatar
What brand rocker is that? Almost looks like a Pro Mag....is it 3/8 or 7/16 stud? If possible, can you get a picture of them installed and lashed on the stud? How much are you lashing them and how are you lashing them? Are you sure you have the flat part of the trunion up and against the poly lock?
Here is a shot of mine. I didn't take it looking at the space between the bottom of the rocker and the stud, but you can see how much space is there. I have 7/16 comp cams studs and 7/16 NSA Comp Cams Pro Mags.
ACE1252 is offline
Old 09-06-2011, 08:26 PM
  #19
That's a Comp Pro Mag for sure, wish I was local to check out the geometry. If all else fails Summit has some budget 3/8 and 7/16 rocker studs for $25.
Is the arm showing wear on the retainer as well?
-Dustin-
Old 09-07-2011, 04:21 PM
  #20
Ocala93TA's Avatar
Iam not sure the brand name but theres no wear anywhere but where the pic. is . The entire problem is using stock 7/16 stock rocker studs and yes i had them installed correct believe me that was first thing i checked , Iam 100% positive if i go to apr or comp stud that it will solve the problem . I took everything apart and waiting on parts so no pics of it installed sorry about that
Old 09-07-2011, 08:19 PM
  #21
MachinistOne's Avatar
-Dustin-
Yeah - looks to me like the retainer is digging into the arm of the rocker as well.
MachinistOne is offline
Old 09-07-2011, 10:46 PM
  #22
Ocala93TA's Avatar
No i had a spring break a few months ago and thats what it did to the rocker
Old 09-07-2011, 11:09 PM
  #23
Ok....point is that we could both see that the rocker is damaged regardless of the cause...and if you're not going to replace that damaged rocker you need to at least polish out those gouges as those are perfect stress risers that will cause a break.
Old 09-08-2011, 06:29 AM
  #24
Ocala93TA's Avatar
Wouldnt polishing out more of the area make it even weaker ?
Old 09-08-2011, 09:20 AM
  #25
bw_hunter's Avatar
Nope, those gouges left sharp edges that the metal can crack along..stress risers. A smoother area with no sharp edges doesn't have these risers.
That metal is plenty thick and can stand a little polishing without Ill effects.
bw_hunter is offline
Old 09-08-2011, 03:19 PM
  #26
Ocala93TA's Avatar
That metal is plenty thick and can stand a little polishing without I'll effects.
Cool , Iam going with new rockers anyways but thats some good info thanks
Old 09-08-2011, 05:04 PM
  #27
Listen to what MachinistOne tells you.... he's without a doubt the most knowledgeable engine builder on this site.
Injuneer is online now
2QUIK6
07-15-2015 07:46 PM
MadMav
06-15-2015 09:51 PM
KamikaZ28
05-28-2015 12:45 AM
DirtyDaveW
03-15-2015 07:01 PM
Quick Reply: Rockers hitting stud
