rubber o-ring washers with intake gasket set?
Re: rubber o-ring washers with intake gasket set?
Yeah, they are for your fuel injectors but as long as you don't have to take the injectors out for any reason, don't even bother with them. I just did my intake gasket swap this weekend (rear seal oil leak... Blah!) and just disconnected my fuel lines and pulled the entire fuel rail along with the intake manifold. Pretty easy gasket swap.
10-31-2016 11:09 AM
Brandon Wittmer
12-08-2014 07:53 PM
