ruben jr 94z28 lt1
#16
Re: I beg your pardon?
#17
Re: ruben jr 94z28 lt1
@ speedygonzales..i do have a consistent dtc16 according to the instructor and students..when they put the new flashed pcm the code poped up after test drive, they reset it, test drove it, light come on again, they put the scanner and again dtc16 came back again.my car runns good for about the first 1-4 minutes,then stumbles for about 3-5 seconds as if it wants to turn off while driving, the service engline light turns on. and when it is driven about 20 miles,when i turn it off, it wont start for a while. it will crank but not start..just yesterday i drove it for about 10 mins..turned it off..turned it on and drove around the block and it stumbled all the way back to the house..so i drove it about 5-10 mph home
#18
With reference to the DTC 16
Check all the connections between the opti and the PCM for signs of corrosion or anything else unhealthy.
If that all looks good, put a scope on the red/black wire and look at the square wave while the engine is running. See if the signal drops out occasionally.
Based on the symptom, the problem, and code. Neither a tune up, nor an ICM is warranted.
Stick to the problem and it's symptoms and do good investigation. This is the perfect time for your instructor to pull out the scope and review it with the class.
Don't simply buy an opti. YET.
#19
Hey get back in your seat
If you're not gona get along with the others, I'm gona have to call the principle. Now get back to your seat.
#20
Brad122470
08-02-2002 08:55 AM
