runing wires after longtubes, #5 cyl...
i have huge rigging issues going on in my engine comp. ...i have wireties runing to brakelines suspending the wire so it doesnt melt for a temporary fix....i think its the #5 plug, but not sure, its 3rd from the nose on drivers side.........i just cant seem to keep it from laying on that header tube...how did you guys run yours?...any info aprecaited--thanks
Re: runing wires after longtubes, #5 cyl...
this is going to sound very ghetto but, take a a zip tie and tie it to the number 7 wire as an anchor which will hold number 5 at an angle away from the header primary and keep it from being burned. But cut a piece of rubber hose down one side and put it iver the wire to keep it from arching off the other wire, or else at night it will ook like the 4th of july,not good. Hope that helps
armedtrigger
02-24-2015 08:30 PM
