running rich
running rich
Over the past two years or so I have noticed the car has been running richer and richer. First was gas mileage then a little black smoke so I checked the oil and sure enough it smells like fuel. What can cause this? All the plugs look great and the car runs fine, I'm just worried about washing the rings or wiping out a bearing :s is there anything I can do through the pcm (Delete o2 sensors, etc.) That will help? Thanks, Chris
Things that cause a "false lean" condition, causing the PCM to add fuel the engine doesn't need:
-misfires
-exhaust leaks before the O2 sensors
-defective O2 sensors/wiring
-high overlap cam
-O2 sensors in open header collectors
Things that dump fuel:
-leaking fuel pressure regulator
-excessive fuel pressure
-leaking injector(s)
-faulty tune
If the plugs don't look bad - e.g. no carbon deposits - its probably not running rich. Are they ALL clean? A leaking FPR for example, dumps fuel in the rear cylinders.
-misfires
-high overlap cam
-faulty tune
Funny you would mention a false lean condition. Took it for a drive just a few minutes ago and the ses light came on. I had my tuner from Trifecta with me. So I scanned it right away. Got code 44. Left o2 sensor lean. I'm thinking now it's a faulty sensor, maybe pcm trying to fix a problem that isn't there..
You would be wise to check the plugs on both banks to confirm what the code reader says. Since you need to replace the dark ones anyway.
But since you've been driving it this way for 2 years, it needs a lot more than just plugs on the left bank and a single O2.
Wide-bands? Then you are going to use emulation mode for the wide-bands to send a 0-1V signal to the PCM? You can't just plug a wide-band sensor directly into the stock PCM.... they have a 0-5V signal.
Honestly though you should get it on a dyno and have it tuned.
More time "reading" is necessary
Speeds8erM-1
07-18-2002 11:36 PM
