running warmer than normal
I recently (couple of weeks ago) completed the rebuild of my LT1 and before the rebuild the temp gauge rarely ran more than just over 210 now with the new mods the temp rides around the next mark (230?) before the fans kick on, then just below that mark. My fans were tuned at 205/215. My question is could the heads be running that much hotter than the temp sensor on the wp reads for the pcm? And if I change my thermostat to a 160 will this help lower the temp?
Mods in sig on the 84 - things that changed are heads, cam, intake, tb, injectors and of course new tune.
Also both sensors have been changed, and I am still using the same temp gauge as before.
I think it has the stock 195? stat in it. Mix is fine.
ordered a 160 (hoping that will help), radiator and block have both been flushed in the rebuild
Alex Barnes
01-24-2015 10:21 PM
edman
01-22-2015 02:45 PM
