Runs great for bout 30 mins then starts running like its on 4 cylinders
Old 01-15-2013, 10:26 PM
  #16
slick1hunting's Avatar
Re: Runs great for bout 30 mins then starts running like its on 4 cylinders
In the hot condition when you turn key do you hear fuel pump prime? I would check that first as mine has been acting weird since the vats was disabled and when I pull my pcm fuse my fuel pump doesnt want to get signal for a while even with security light off.
slick1hunting is offline
Old 01-15-2013, 10:33 PM
  #17
D'Z28's Avatar
yes fuel pump primes just wont start till it cools off a bit its the only thing im waiting to fix b4 paint dont want to b crawling all over car after fresh paint lol
D'Z28 is offline
  #18
Also did you check for leaky injector or just assume you dont have one based upon it running for an hour and good on cold starts?
Old 01-15-2013, 10:37 PM
  #19
D'Z28's Avatar
had fuel rail off after prime no leaking its got me stumped never had a injected vehicle do that
D'Z28 is offline
Old 01-15-2013, 11:08 PM
  #20
Originally Posted by D'Z28
Ok hears what we found tonight massive miss number 5 running rich as all get out icm tested 6 times got slower as we went along ran for bout 10 mins died can smell gas wont start smells flooded so gonna change plugs and pull o2s to check them seems to b runnin rich when it is runnin heck idk im over it
Almost impossible to understand this with the total lack of punctuation, but if I read it right, you tested the ICM 6 times, and SOMETHING got slower each time. Do you mean it became harder to start (took longer) on each successive test? Did you apply heat to the ICM while it was being tested.... a hair dryer is a handy tool.
If the ICM is shorting internally with heat soak, or creating an open circuit, it should set codes and those codes DO NOT turn on the SES light. Have you scanned it for codes?
Injuneer is offline
Old 01-16-2013, 07:39 PM
  #21
D'Z28's Avatar
Yes scanned thats how we found o2 sensor not reading ! And im past that point now car is running good now . THANKS 4 THE HELP GUYS
D'Z28 is offline
Scottylt1
01-08-2015 02:48 PM
skittlez87
12-29-2014 03:23 PM
Scottylt1
12-04-2014 12:31 PM
nophix
11-30-2014 10:26 PM
Lederman1976
11-30-2014 05:21 AM
Quick Reply: Runs great for bout 30 mins then starts running like its on 4 cylinders
