Runs Great Until 5000RPM - Then Misfire
Old 06-20-2009, 06:21 AM
  #16
Originally Posted by ENRKyle20
ok. I did a rev with the clutch in, went right up to 6800 no problems, no misfire, nice and smooth. This is a decent indication that the ignition is up to the task (at least while not under a load, but I cant image that changes TO much for the ignition system). So no I am leaning a little close to fuel filter not being able to flow enough at that rpm under load.
But now i have other problems to chase, after that rev I lost all oil pressure. Started a thread in the LT1 section about that.
yea when you got the throttle open it gets a lot more air in the cylinder and and more gas, then its compressed, that's more stuff making it hard for the spark to jump. more stuff resisting the transfer of electricity. I already have them gaped pretty small to try to save my opti and to prevent problems like this. its at .035"
if its harder to spark in the cylinder then it may find an easier path outside the combustion chamber.
What changed your mind?
Injuneer is offline
Old 06-20-2009, 12:19 PM
  #17
ENRKyle20's Avatar
i have been out of the game a while. I am ASE certified, but I don't work in the field anymore. But I got to thinking about my schooling and I remember spraying ignition systems down with salt water trying to find a arc. We were instructed to load the engine (gas and brake with a automatic - for a short period of time, or on the dyno with a manual).
ENRKyle20 is offline
Old 06-20-2009, 07:39 PM
  #18
userchemical's Avatar
cough...
Originally Posted by userchemical
well i can tell you from experience its your ignition system. Time to do opti, plugs wires and maybe a coil.
First check your coil see if its missing. spray the coil with some water and look for sparks coming off the boot. If you don't see any sparks that means that the wire boot is still nice there. I would say spray your opti too, but it would be dead for sure after that and you can barely see it. But either way that's your problem, the opti. While you're there might as well do plugs and wires. if you know what you are doing its a 1.5 hour job.
i guess you didnt read very well, first thing i told you to do that. use windex works well, or soapy water.
userchemical is offline
Old 06-21-2009, 03:52 PM
  #19
Tex95Z's Avatar
not with pacesetter midtubes..
Mine 95 has pacesetter mids, I can get all changed in under 15 minutes, I remove all but 5 & 7 from the top, however # 6 & 8 are a little tricky. Do you have any burned/melted wires?
Tex95Z is offline
Old 06-21-2009, 05:48 PM
  #20
ENRKyle20's Avatar
the wires all look good. I made sure the rout them out of the way of the exhaust when I put it all back together. I zip tied them all together, they are MSD wires I am unsure of the size. But being that its so easy to change them I think I will, and I will get the required brackets to run the wires above the exhaust from the valve covers.
Old 08-12-2009, 07:22 PM
  #21
ENRKyle20's Avatar
It ended up being excessive back pressure.. my exhaust was holding is back so much. I took my Y pipe off and ran open header and it revs perfectly to fuel cut off and fast to. I plan on installing my SLP loudmouth Tuesday and that should flow a lot better than the junk flowmaster setup I have on there now.
Alex Barnes
01-24-2015 10:21 PM
Scottylt1
01-08-2015 02:48 PM
Scottylt1
12-04-2014 12:31 PM
nophix
11-30-2014 10:26 PM
Lederman1976
11-30-2014 05:21 AM
Quick Reply: Runs Great Until 5000RPM - Then Misfire
