rusty wire???
rusty wire???
ok guys my car was missing really bad the other day and since i work at a gm garage i hooked it up to our tech-2 and went thru and shut off each injector until i found out which cylinder was missing ,well it said number 8 so i took the plug off the opti and it was alll rusty so i tried cleaning it up, didnt work to well, and stuck it back on,,,, its an msd wire, do u guys think my opti is toast, its still missing by the way, its on a 95 z auto with 65,000 miles
Well if you are sure that it is just the 1 cylinder that is miss firing than i would replace that wire and pull the plug also to see if is carboned badly and replace it if it looks bad and then try it.
surreybrad
04-22-2015 06:40 AM
Brandon Wittmer
12-03-2014 09:28 PM
