Salad Shooters and 255's
The 255s are a bit taller than the 245s. I had 255s in the back and 245 in the front and I definetely noticed the difference.
255s are 26.4" tall (calculated)
245s are 25.65" tall (calculated)
The speedo will be slightly off with 255s.
255/50-16 works out to 26.04". That is a 1.5% increase in diameter, which means your speedo will read about 59MPH at a true 60MPH.
