sbc roller rockers on lt1
Re: sbc roller rockers on lt1
LT4 Hotcam Kit(P/N 12480002) rockers are made to fit in the LT1/4 heads and are delf adjusting 1.6 roller rockers (P/N 12370839).
EDIT: Notice you're using 7/16th studs, my bad.
[QUOTE=greenformula94;6891242]Do sbc roller rockers fit on lt1's?
I think you need self aligning rockers for LT1? Unless you have pushrod guide plates, then maybe you don't...
yeah the old roller cam 87-99 sbc's have narrow body self aligning rockers. They will work on LT1. If you went guideplates, you probably can run any sbc rocker you want. Just need to make sure you have good geometry with the guideplates and pushrods.
oldschool
02-09-2016 09:21 PM
