Send me your MSD 6AL instructions!
OK I'm new to all this stuff so I got some ?s.....
Where is the coil and how do I know which is the positive side and which is the negative? It says I need to connect to a 12 volt source? What does that mean?
Ok, first I suggest you to get the wiring harness PN# 8876
It makes the installation with the stock coil plug'n'play. No need to worry about negative and positive sides.
The coil is in the side of the drivers side cylinder head. You can see it at Shoebox's page. Here you can find a lot of useful information as always!
Yeah, you have to connect the heavy red wire to the positive terminal of the battery, and the heavy black to a ground point.
Hope this helps!
Hope this helps!
10-31-2016 11:09 AM
Drtryder
04-22-2015 04:17 PM
