service engine soon light, fans stuck on. help
Well, I got my car back from the shop (had a new tranny installed), and on the way home, I get an SES light. I notice that my fan switch is off, but both of the fans are goin, and the temp is good, around 160-180. Somethings telling the car that its overheating, when its not. Anyone know what the problem might be? thermostat?
Originally posted by Van5150
I have same problem. Check your Air Pump fuse, is it Blown ? It is located in engine compartment.
I had problems with the air pump fuse as well..
Well until I removed it..
I'd check the fuse for that first.. Might be that simple for you
Originally posted by KeVMaN
wheres it at in the engine compartment?
Since you have a 1993, you can pull trouble codes yourself and see what the SES is for.
Originally posted by shoebox
In the underhood fuse/relay center behind the LH headlight. The fans come on because of the SES-that's normal.
OK..makes me feel a little better. Mine have been running an awful lot I thought. I have several codes triggered by removal of air pump, egr, rear O2s, and the like. Guess i should hit up pcmforless sometime. Thanks for the info.
