Setup Questions
Setup Questions
So im doing a "cam only" setup on the replacement motor im putting into my formula and have a few questions. First off the setup
Crane Gold 1.6 rrs
Miezere electric waterpump
cc503: (224/230 .535/.544 112lsa) w/ 1.6RR's
Crane 10308 valve spring kit
Pacesetter Longtubes and true dual(should be soon)
Progear Timing set
Polished Stock tb
ASP underdrive pullies
3.42 gears
M6
First question is will the crane valvespring kit work properly with the SA rockers and cc503? Should I be able to get away using the stock pushrods without issue? Idea on numbers or times this should net me?
Crane Gold 1.6 rrs
Progear Timing set
Polished Stock tb
3.42 gears
M6
Well I was under the impression that the crane golds were only sa rockers but looked into it and realized it was both. They were on teh car when i bought it and the previous owner isnt sure which they are...so how do I tell?
Thanks for the info, and yea im going to just run the sa rockers and upgrade my lifters to ls7s while im in there.
Which spring kit would work better, the crane 10308-1 or comp 26918? Ive been told the comp springs will work better and also other then the springs and retainers what else will I need?
There have been several debates as to the pushrod cup depth being deeper than stock. Buy the $20 tool and just check to be sure.
10-31-2016 11:09 AM
Sergio
01-27-2016 04:27 PM
