Shaft mount rockers
Old 03-31-2008, 06:31 PM
  #16
MeanGreen97Z's Avatar
I recently pulled a set of shaft mount rockers off of a friends car after the fulcrum came apart on one of the rockers. One of the rockers wasn't tightened down as it should have been and it backed out breaking the fulcrum. I've seen cams with that lift using 1.5-1.6 roller rockers without an issue. Depends on the rpm and aggressiveness of the cam though. You may want the added assurance of shaft mount due to high rpm combined with high lift.
MeanGreen97Z is offline
Old 03-31-2008, 06:37 PM
  #17
quickSS's Avatar
Originally Posted by LT4BLAZER
You seem to have built quite a few impressive engines based on the lt1/lt4. I talked to Joe at Jesel this morning and he doesnt seem to be confident that the sportsman series shaft rockers are strong enough to handle nitrous, blower or turbo. He states cylinder pressure on the exhaust valve is excessve and might cause failure on the Sportsman Series.I have 250 shot nitrous and don't want to break the rocker just because I chose the cheaper set. Is he just trying to boost sales of the competion series? or is there credibility to his statement. You have run a few of the sportsman series. Have you had any fail with nitrous or forced induction? I am buying a set and need information before I place my order. Thanks for any help!!!
Good questions. I don't have long term experience with the Jesels and customer blower motors and nitrous motors. No failures yet but I don't think there has been enough time and extreme usage on my customer motors. I should put a set on one of my personal motors for testing of this sort. (I have Cranes and T&D on my personal motors).
I'll keep close attention to the longevity of the Jesel Sportsman series.
Karl
quickSS is offline
Old 04-30-2008, 11:16 AM
  #18
BADASS96TA's Avatar
Quick, what is the part number for the T&D rockers. Also are thier any issues with them on AFR 220 head. I have a 383 converted to carb and we are spraying 350 shot.
Thanks in advance
BADASS96TA is offline
Old 04-30-2008, 11:58 AM
  #19
tapout911's Avatar
T&D shaft mounts here. No issues at all. I run a pretty agressive cam close to .700 lift. Ive had to re adjust the valves once after initial break in. Shift the car at 7k and drive it to the track.
tapout911 is offline
Victor Lamb
08-26-2017 02:52 PM
HectorM52
07-30-2017 11:46 AM
Jasonz28camaro
06-07-2015 09:14 PM
Jasonz28camaro
West South Central
06-07-2015 09:12 PM
DirtyDaveW
03-15-2015 07:01 PM
Quick Reply: Shaft mount rockers
