Shoebox... Need Ur Help With This...
on the left side of the TB, theres the hose that goes from the TB to the pass side Valve cover, under that hose there is a rubber elbow that connects to a plastic line, what is that rubber elbow with 2 different ends and perhaps you know the part #, mine has a crack in it, I wrapped it with elec tape for now, but I prefere to replace it, I appericate your help and I figured if anyone knows what it is, YOU THE MAN!!! Thanks bro....
Pretty sure this is it.. goes to the 'canister purge solenoid'
It's a small plastic line with a rubber elbow on one end and a straight one on the other.. about 5 bux from Jason Cromer..
Evap Canister Purge Solenoid Pipe p/n 10105324
# 5 in shoebox's pic here:
http://csce.uark.edu/~jgbertr/rb/1995_evap.jpg
If it is item 5 on this diagram, Charlie gave you the right part #.
slothgrant
15
12-11-2003 10:40 PM
JasonD
07-15-2002 02:17 PM
