Which should I get?
Which should I get?
GRANATELLI MASS AIRFLOW SENSOR
Completely replaces OEM sensor, recalibrated, bigger inner diameter, add up to 15hp in 5 minutes. 100% 50 state smog legal.
Year Application Part No. Description Price Add to Cart
93-97 LT1 GRN193 MASS AIRFLOW SENSOR-specify color $279.99
85mm ZO6 MAF conversion
Bolt on up to 18hp in minutes! Specifically calibrated for your 94-97 LT1 powered F-body. Includes current 2001 ZO6 85mm Maf meter, sleeve, clamp and wiring harness adapter.
93-97 LT1 GRN9485 F-body 85mm MAF meter $149.99
SPEED INC. HIGH FLOW MAF ENDS
Replace outer housing with these high flow units, available in plastic, natural aluminum, and red anodized. Easy 15 minute install.
98-02 LS1 IZM298 MASS AIRFLOW SENSOR ENDS-PLASTIC $89.99
98-02 LS1 IZM298A MASS AIRFLOW SENSOR ENDS-ALUMINUM $99.99
98-02 LS1 IZM298R MASS AIRFLOW SENSOR ENDS-RED ANODIZED $109
Man that thing is SUCH a waste of money, he shouldnt even be able to sell that thing, cant believe its still on the market,you wont gain anything..put that 300 something dollars to some good heads
Antz97ZNJ Man that thing is SUCH a waste of money
Originally posted by RedPhenx
save for heads..
but i got the grannatelli thing for 25% of retail(returned Item) ive had it on for two years and havent had any driveability problems..
save for heads..
Rich Krause
