Should I replace the coil??
Re: Should I replace the coil??
You'll find people go both ways on coils, some people say it makes no difference some say it does. No one ever provides supporting evidence, some manufactures like MSD make claims that their product is superior however you will not see an increase of power if thats what you are suggesting.
Yes there is only one coil, its located next to the water pump on the drivers side
Also why do you believe the hestitation is due to the coil? It could very well be a number of other things related to your ignition, like the opti for example.
Its cheap, I'd say go ahead and replace it with an aftermarket one if it gives you peace of mind.
- Z28WannaB
- Z28WannaB
10-31-2016 11:09 AM
grabbem88
03-18-2015 01:25 PM
Alex Barnes
01-24-2015 10:21 PM
