should i use gasket seal when mounting elec water pump on stock housing
basically what the title says. just wondering if i should use gasket seal when mounting it to stock housing not to the block itself. any opinions are greatly appreciated.
Re: should i use gasket seal when mounting elec water pump on stock housing
My personal favorite is Ultra Black, but you typically don't need a lot unless you're filling large gaps. I used just a thin coating on my EWP when I put it in the housing.
Not to mention the black blends in better than blue or copper unless those are the colors of your motor.
10-31-2016 11:09 AM
