Should i use a High volume oil pump or not?
I am in the process of rebuilding my LT1. I bought a rebuild kit from summit that came with a high volume oil pump. Should i use this one or just a melling standard volume pump.
thanks
Shawn
thanks
Shawn
Originally posted by NOMAD
I've had a HV Melling pump on my car with a stock pan for about a year now with no problems and I honestly don't see how this can even be bad for a forged botom end.
-Shannon
-Shannon
One of the biggest problem LT1 drivers have is the fact that the GM pan sucks. A stock volume oil pump can be made to cavitate with out much difficutly. By putting in a HV pump you significatly increase the risk of this happening.
Fastfoward to the fact your car is modified, now you will have a even greater risk of sucking air than oil - and trust me, bearings prefer oil. I honestly wouldn't build a motor without a Canton or similar pan. Its the best insurance you can put on your motor. The factory pan has no baffles and the pickup is to far up in the pan for a performance motor IMO - just a bad design. With a canton or other aftermarket pan they should have baffles and traps usually with a lot better windage tray as well.
The only time you would have to worry about the stock pan being sucked dry is if you are running your car at high rpm for extended periods of time such as if you are road racing your car. In normal driving and drag racing etc you're not at sustained high rpm. A hv pump just pushes more oil thru the engine so for me I prefer to have the additional volume for the bearings than not. Just my opinion.
I had a chat with Nick from Nu-Tek Motorsports about this. I have a HV pump on my stock oil pan.
He's running several cars with the stock pan and a HV pump with no problems also.
So its a matter of opinion and how the engine is assembled.
High rpm with HV pump sucks stock pan down in no time. No oil=dry bearings=afternoon revisting the fine art of motor rebuilding.
Well that sucks........... I was gonna put a HV oil pump on my car when I did the heads and cam. I have this weird problem where on second gear pulls the oil pressure will drop down as much as 25psi, stay for a second then come up to normal again.
I really don't want to get an aftermarket oil pan, I don't have the money.
What about a HV oil pump, running a bigger filter and overfilling the oil pan some??
John
John
John
John
I ran a melling high volume / high pressure pump in my car - until I managed to shear the teeth off the oil pump drive gear.
Now I'm running a moroso anti cav "racing" oil pump w/ a high pressure spring and have had absolutely no problems. On a side note - my car doesn't use as much oil now as it used to... wierd
