Should the optispark deter me from buying an LT1?
#31
I've had nothing but good luck with mine. In the 11 years I've owned the car the opti has been changed twice. I still have the stock original and it still works. It was changed out at 115K miles just because.
The stocker did experience the loose rotary screws after 30K miles, but that was fixed easily.
Indubadably...
I'd like to know how many good optis have been thrown away that have been exposed to moisture... That thought makes me sad.
Indubadably...
#32
from what ive read, the LT1 plug change isnt as bad as my old car... 93 tbird SC
just look at this
the dist. on that car is cake though, 4 bolts and your done... if you can find one, lol (summer 2000 there was a 3000 national backorder on the "DIS" box for the SC and taurus SHO)
just look at this
#34
It's kind of funny how the vented opti's are well regarded. My 93 Trans Am as well as my friends 94 Z have 130k and 140k respectively on the original optis. Where as two of my other buddies, both 96's have had nothing but problems with theirs.
#36
the opti is not as bad as people make it sound i have never had a problem i have washed my motor with a hose i spraied the opti and nothing happened (i was 16 and didnt know better), and when i did my throtle body bypass it spilled all my coolant right on the opti i freaked out but nothing happened.
and i am at 130K stock opti
#37
I wouldn't let it deter you. Mine ran fine for at least ~115k miles, including through one water pump death with the previous owner around 90k, and only was replaced as part of my cam/timing chain/etc. install.
#38
No opti problems with the 2 LT1's I have had so far. I do have a high RPM miss in my current 95 Firehawk but I think its because I have the original plugs, wires, cap and rotor in it. Its got 53k on the clock right now. Not bad for the originals. Ill be changing those soon to see if it takes care of my miss above 5200 rpm's. So, I would not let the Opti steer me away form the LT1 cars. Not as bad aas people say it is.
10-31-2016 11:09 AM
