Single plane for a healthy low clearance 383?
Old 10-24-2008, 05:06 PM
  #16
LT1 POWR's Avatar
Originally Posted by Masnart39
The Procharger hat won't fit under a stock hood pointing forward. It will almost fit if turned to the passenger side, towards the firewall. That would still require milling the the surface that mates to the TB on an angle so that it tilts down slightly. At least that's what I found on my Accel single plane & 4bbl style TB.
I was able to take the Accel 90 deg elbow, and take a pie cut out of it tilting it down to fit.
How tall is your accel single plane. I think my vic jr is about the shortest single plane out there, not the best for performance, but better for low clearance. I had planned on building an elbow that will allow me to use a 4 barrel tb, but it looks like I will have to do a 90º elbow and a 90mm tb.
LT1 POWR is offline
Old 10-24-2008, 06:04 PM
  #17
Masnart39's Avatar
It's probably a couple of inches taller than a vic jr.
Masnart39 is offline
10-31-2016 11:09 AM
Drtryder
04-22-2015 04:17 PM
carl.froehlich
03-13-2015 12:38 AM
Elcojoe
11-17-2014 10:27 PM
Quick Reply: Single plane for a healthy low clearance 383?
