Sister Is An Idiot!!!!!locked Keys In Car Heelllppp!!!!!
I hate my sister, i let her drive my car and what does she do, lock the keys in them. Is there anyway to get in, besides breaking the window I have keyless entry if that helps. I have a lot of sheet metal so i could make a jimmy stick, but im not sure if u can jimmy these cars. PLZ HELP!!!!!!!!!!! BEFORE I KILL MY SISTER
donno really, if u have a spare door key someplace else... if u call AAA they can make u a key on the spot for ur door... or they can break in for u w/ causing problems
other then that i donno what to tell u i donno much about the keyless entry
Originally posted by Seal
i've slim jimmed MANY cars, and i've done tons of fbodies... so yes its possible, if you know how to, it'll take u 5-10 mins (its a bit harder with power locks)
My driver side window was a little sloppy and I could detach it from the weatherstrip just enough to fit a pool cue through it and push the unlock button. Something thinner will work better but that's the only thing I had and could think of at the time.
Well this is what I did in order to get my locked car open.
Stretch a metal coat hanger out. Stick in your, oh, thats another story.
Ok, stick it in between the window and the rubber. You might have to grab and pull down the window with your hand just a tiny bit for the coat hanger has room to move around and just aim for the lock on the door.
West South Central Moderator / Special Guest
use a coat hanger (or something thicker.. I have used an antena before!!) pull back the glass a little, and use it to pull on the luck/unlock lever.. pull it forward.
I bent an antenna with a slight bow to it, and then bent the end about 140degrees like a hook.. used that hook to snag the lock lever.
done this MANY times between my car and all the fbody friends I have.. put it this way, with ZERO tools I can break into an fbody in about 30seconds
ChrisFrez
11-30-2014 08:41 AM
