Slp Cai
it's a good looking, high quality, great flowing piece. you shold be happy.
if i remember correctly, it is metal tubing. some claim it has more heat soak. but i think it's BS. the air is flowing way to fast for it to soak up that much heat.
just be carful not to scratch or dent it. that's the advantage of the plastic ones...since most mods to the engine are easier if you remove the intake. could get dinged up over time.
I have it. Its a nice CAI, easy to install and looks real good. My only complaint with it is there is little room where the two filter go, to tighten/loosen the filter clamps (this usually takes me about half an hour to do - too long when its only 2 screws). Other than that, no complaints.
