SLP Fan Switch install, where to....
I did a search and was unable to see any real installs for this. Not that it is complicated at all i just was wondering, in what area did people drill through the firewall to route the switch? I havent a clue where. To the people who have done it or know of it being done, where is the most convenient/effective area to route the switch through the firewall? Any little "tricks" to make it easier or things not to do? If this is in wrong section i apologize, seeing as is a fan switch it could fall into Lt1 or audio/electrical so....
Re: SLP Fan Switch install, where to....
The best place to route wires is already drilled and grommeted for you. Behind the PCM, passenger side, is a large grommet that is fairly easily accessible from under the glove box. Go at it!
RamAir was spot on. Installed it 10 min after seeing his post and it was a piece of cake. Routed it through the grommet, under the dash and mounted the switch right underneath the lighter. It was like Chevy left a nice, square space right there for that exact purpose Thanks!
Richardan15
05-30-2015 08:36 AM
Rich_z28
08-29-2002 10:44 PM
slothgrant
08-22-2002 03:01 PM
