SLP LT4 or McLeod ST???
#16
Re: Re: SLP LT4 or McLeod ST???
Originally posted by IllusionalTA
If you aren't concerned w/ price and don't mind working out that left leg a lil.. The Street Twin is worth every penny.. and can be rebuilt time and time again for 325 dollar's.. i have it and it has only snapped one driveshaft, one output shaft, and twisted the spline's on 3 steel driveshaft's.. Uprgraded to a spohn extreme duty and don't have no more problems..
I have also snapped one driveshaft and twisted the splines in the slip yoke of a Denny's Nitrous driveshaft.
#17
Originally posted by 95Blackhawk
Here is what I did:
Went down to Autozone and bought myself a new clutch for $250 (some area of US sell it for $200). It will have a warranty and it uses the LT4 pressure plate which gives you more holding power.
Now, later if you start to wear the clutch again, just get a new disc. If you want, try a different one from Spec.
Here is what I did:
#18
Originally posted by J's 82
I just did the same thing.. the pressure plates are identical down to the serial numbers.. the whole setup 199.00 and holds just fine.. don't think you can beat that deal..
#20
Identical to a mcleod pressure plate I have in my garage.. only the autozone one is not painted red.. every number matches including the manufacturer.. I posted about it on here before apparently it is some sort of patent by valeo on the pressure plate..
#21
I have an SLP PP with a Mcleod kevlar/organic disk. it's listed as the performance disk for shifts above 7500 RPM. I'm really happy with mine. I've beat the **** out of it and it never slips, is 100% as driveable as stock and doesn't chatter. At your power level I'd reccomend either a stock disk or the Mcleod with an LT4 or SLP(LT4 with holes drilled) pressure plate.
The ST is overkill for a bolt-on car. You could get away with a new stock LT1 setup just fine, but a mcleod/SLP combo is very similar in price.
