SLP Shortie headers
#16
Guest
Posts: n/a
Any header will leak if you dont tighten it right, that's first. You tighten them from the center bolts outward, and use good gaskets. I wouldnt loktite them personally, torqing them properly usually does fine if you do it right and put enough grunt into it (torq them to spec) you'll have more trouble trying to make sure the y-pipe seals to the headers.
turbo_Z
08-19-2002 10:50 PM
