SLP TOTL is too quiet...
#19
Re: SLP TOTL is too quiet...
Originally Posted by bg552
So what about removing the cats vs getting high flow cats?
But re-read my post again...If you want your current set-up a lot louder at idle and down low, you're going to need to switch cat-back systems or mufflers to something much louder (an open cutout also works great like I said). Or you'll have to install a choppy cam to hear the 2OTL wake up at idle...
#20
Originally Posted by 2000LS1Z28
Putting an offroad pipe in place of the cat will make the car a LOT louder at WOT, but it won't be much (if any) different at idle and at part-throttle rpms around town. That is what happened when I used to have an offroad pipe with my set-up before I ended up welding in a highflow cat because I didn't like the tinny sound of the ORP...
#22
i love my 2otl, LT's no cats, ory, 3 inch i pipe... sounds great at idle and better and WOT... altho i do have a small cam ccxe 224-230, and stock ported heads...ill try and get a video of it tomorrow..
