small amount of white smoke..
Old 05-08-2009 | 01:40 PM
spyder24's Avatar
ok i have been having problems with fuel getting into my oil so i havnt been driving my car.. and as its been sitting for a couple months ive been starting it occasionally and recently i had it running and a small amount (more as it runs) of white smoke is coming from under the drivers side exhaust manifold. or somewhere around there.. anyone know what this can be? ive heard head gasket. it also smells sorta like antifreeze the smoke that is..
Old 05-08-2009 | 02:16 PM
pizzi-man's Avatar
What do you consider a small amount. You are not helping a motor by just starting it occasionally. It needs to get up to temp so that any condensation in the motor will be heated up and dissapate. Also if your getting gas in the oil, your probably washing the cylinder walls with gas so they arn't getting lubed.
Old 05-08-2009 | 03:59 PM
moparman's Avatar
Check the coolant level in the radiator, not the overflow. Check the oil and see what it looks like.
Old 05-08-2009 | 08:58 PM
redcamaroz28's Avatar
White smoke = coolant. Do a compression check and/or a coolant pressure check.
(Blue smoke= oil, black smoke=fuel BTW).
FredM
06-05-2015 05:45 AM
Brake_L8
01-20-2015 09:44 AM
Sandersen511
01-13-2015 03:49 PM
trefidy
07-26-2002 03:40 PM
Quick Reply: small amount of white smoke..
