Small leak at water pump bolt
I recently replaced water pump, radiator, and heater hose assembly. All is well except a small coolant leak at one of the water pump bolts. Luckily it drips out the front of the water pump, as to avoid the opti. My Haynes manual did not specify using teflon tape (or something similar) on the water pump bolts, and as I've found in these posts, it should be used since the bolts enter the coolant jackets.
My question is this...can I avoid redoing the entire water pump by removing one bolt on the pump, apply the teflon tape to this one bolt, and replace it without altering the present seal of the pump? If it matters, it's the top left bolt (of the 6), when facing the front of the engine. Thanks for any input.
10-31-2016 11:09 AM
