Some one Tell me whats going on Here!!
Old 01-12-2005, 12:14 AM
  #16
Re: Some one Tell me whats going on Here!!
You don't need a "new" file... you just "export" the old one.
Injuneer is offline
Old 01-12-2005, 12:34 AM
  #17
c0rey's Avatar
Here is a csv file.
http://briefcase.yahoo.com/trickedoutblazer
c0rey is offline
Old 01-12-2005, 04:56 PM
  #18
c0rey's Avatar
Alright checked all the plug wires and they are in the right order. I can get it to idel but right as soon as i touch the gas it instantly wants to die. If the opti was on there wrong would it be throwing a opti code or not? I just really dont want to to rip everything back off the opti but I will just to make sure. Let me know.
c0rey is offline
Old 01-12-2005, 09:39 PM
  #19
c0rey's Avatar
Im just confused about the opti. If it was on there wrong would it throw any codes?
c0rey is offline
Old 01-13-2005, 02:45 AM
  #20
Pasky's Avatar
maybe a misfire code if its obd II, other than that, no. Make sure its on right.
Pasky is offline
Old 01-16-2005, 07:27 PM
  #21
c0rey's Avatar
Okay pulled the whole front end off today and triple checked the opti its on there correct. Checked and followed all the wires from the plugs to the proper postition on the opti and they are all correct. I can hear the fuel pump priming. After I got it back together to fire it up again nothing just cranked over and over, so I poured some fuel into the TB directly and got it to fire over but still didnt run good seemed like everytime I would go to push the gas it would instantly die. So This has me thinking it isnt getting enough fuel? Im gonna take a test light and check the injector pulses tommarrow. The injectors are 42.5 lb with less than 100 miles on them. I really need to get this thing running good. Anyone else have any suggestions?
c0rey is offline
Old 01-17-2005, 12:03 PM
  #22
VintageMuscle's Avatar
I had a bent pin once in the MAF...straightened it...fixed.
VintageMuscle is offline
Old 01-18-2005, 04:55 PM
  #23
c0rey's Avatar
Thanks for the input I dont have any converters though. I fired it up today and now I did a data log and they Damn LOW RES Fail Code Came back!!!! How in the hell is this possible the opti has 0 miles on it and 3 times starting up!! It was running decent until I got the damn low res code AGAIN. How could I have toasted another opti? The cam dowel length is good and everything. :scream:
c0rey is offline
Old 01-18-2005, 05:47 PM
  #24
Dave89IROC's Avatar
did ou look at the pins in the harness side of the opti connector?
Dave89IROC is offline
Old 01-18-2005, 06:43 PM
  #25
c0rey's Avatar
Yes and replaced the plug and everything.
c0rey is offline
Old 01-23-2005, 04:15 PM
  #26
Rob(94Hawk#319)'s Avatar
Just to rule out all basic things.. Are you absolutely certain you have gas in the gas tank?
Rob(94Hawk#319) is offline
Old 01-23-2005, 07:50 PM
  #27
c0rey's Avatar
Ya put gas in it.
c0rey is offline
