Some TPS Trouble
Old 12-01-2003 | 05:44 PM
Blown_Red_97z's Avatar
Some TPS Trouble
My car has been spittering an spuddering and the code its throwing is a P0122 code. This says its a "Throttle/pedal position sensor/switch A circuit low input". I replaced the TPS about 3 months ago, and all was well. It seems that it is connected fine and all of the pins are straight. Any other ideas what it could be. I am thinking I might have to open up the wiring to make sure all of the wires are good, and not broken in any spots, but we all know that finding a wiring problem is a lot of trouble. Also, when the car was hooked up to the scanner tool, you could see that the throttle position was making no change when it was displyed on the screen, and the car is idling really high, around 1500 rpm. Any other ideas would be helpful. Thanks
Old 12-01-2003 | 05:46 PM
also, isnt the TPS the only pedal position sensor there is?
Old 12-02-2003 | 12:12 AM
no ideas? anyone?
Old 12-02-2003 | 01:02 AM
96 WS6's Avatar
That is the only throttle position sensor on the car. I believe that you can test the sensor on another car or maybe they do it at kragen or any other auto parts store.
Old 12-02-2003 | 01:15 AM
96z's Avatar
96z
What throttle body do you have? The TPS needs to see a certain voltage at startup. .1-.9 volts I believe. If this isnt met it will throw the PO122 code. Try hooking up a scanner to see its voltage at start up. Try to aim for .65 volts or so. Thats where the factory has it set and from most guys say they get the best results with it like this.
Old 12-02-2003 | 01:19 AM
Thanks, I actually already tested it with my old TPS which was still working, but cracked, and it made no difference. So I guess I have to test the voltage in the wires.
Old 12-02-2003 | 01:31 AM
I have the stock throttle bosy, but how would I adjust the voltage in the TPS? If it reads too high or too low of voltage, whats the next step? To search the wires for a possible break somewhere?
Old 12-02-2003 | 01:47 AM
96z's Avatar
96z
Test across the black and blue wires if you only have a voltmeter. A scanner will show you the same voltage. If you tilt or "swivel" the top of the TPS towards the front of the car the voltage will increase. Move it around in this fashion and you should se some movement there.
Old 12-02-2003 | 04:31 AM
Zeueses 97 RamAir's Avatar
ok
you have to get it at wot above 4.2 volts get a drill and open the holes up.... get the volt meter and adjust leave the car on on and test, once you get it above 4.2 volts at wot you should be fine,
Ericksd
01-20-2016 07:07 PM
truecontr3
10-11-2015 10:30 AM
drt
09-27-2015 05:39 PM
tdigger9899
09-07-2015 11:56 AM
Schul365
08-22-2015 11:00 AM
Quick Reply: Some TPS Trouble
