Spark plug and o2 sensor ?s
I am runing a 11:1 lt1 and runing the tr 55 ngk, what do you think would work best as far as setting the gap on the plug. Also, I installed jet hot longtubes and was wondering where to get o2 extension and what 02 simulater or 02 sensor to buy.
Thanks Guys
Mark
Thanks Guys
Mark
Re: Spark plug and o2 sensor ?s
www.thunderracing.com for your 02 extensions and 02 sims
as far as plugs, I would assume it would depend if you have an aftermarket ignition as well. I would think a stock gap with an aftermarket ignition amp would be fine.
Brian
Brian
Originally Posted by StickMaster
You have a 94, you dont want 02 sims you want new 02s, put them in after you run the new headers for a few hundred miles.
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
