spark plugs- i need help replacing them
Re: spark plugs- i need help replacing them
Time & patience!
Lots of attachments and swivels...and what really helped is taking the alternator out. Also, if you have any wobble extensions, that's a plus.
Do a search too, there's plenty of info here.
Good luck!
Good luck!
Originally Posted by captskin
Time & patience!
Good luck!
Good luck!
what he said...............unless u have headers, then its a walk in the park (compared to having stock manifolds that is, lol)
You will be able to access some from the top and the rest from the bottom. An assortment of extensions, swivels, and maybe an open end stubby wrench in conjunction with a spark plug socket should do the trick for ya.
the only thing as bad as doing the plugs on the stock manifolds was doing the wires in the stock location!
honestly, its not *that* bad. the first time it took me literally days to do (a few plugs each day after work). after having been through the ordeal once before, i removed them in about 30 min or less when preparing for my header install. its all about knowing how things fit - having girlishly small hands and arms helps a lot too. I didnt need to remove alternator or y-pipe to do any of my plugs. Make sure you use a plug socken and 19mm wrench.. there are spots where a ratchet wont fit.
[QUOTE=nfa]the only thing as bad as doing the plugs on the stock manifolds was doing the wires in the stock location!
omg.......YES, i hated doing that.........wtf was i thinking??
Originally Posted by sko_spo
if you are going to do spark plugs and wires, might as well throw a set of headers while you are down there.
i was able to get all the plugs and wires done without removing the alternator. the drivers side wires are easy and the passenger side is easy as long as you cut the original ones then route the new ones however you feel. all i can say is have patience and a strong will and you will suceed.
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
grabbem88
03-18-2015 01:25 PM
