springs to use with cc306 cam
Re: springs to use with cc306 cam
CC985-16's will work great also
if you look thru a parts catalog (Jegs/Summit), most pushrod manufacturers recommend a slightly longer pushrod with aftermarket Comp cams, usually a 7.25" with HR valvetrain over the stock 7.2"
best way to do it is check length after isntall with an adjustable pushrod legnth checker (~$20), then order new ones if needed
99893-16
These are what the guy who sold me my engine is setting me up with. I dont know about pushrods, but I plan on using the stockers with the stock 1.5rockers.
EDIT* - must machine spring pockets? wtf.. i need to talk to him again.
10-31-2016 11:09 AM
