Squeak from engine
Squeak from engine
I have a 1997 Camaro Z28 with a LT1 with 177,000 miles on OEM engine and have run Mobil 1 exclusively. I have a squeak that seems to be coming from the middle of the engine. I have replaced the water pump, and removed the serpentine belt while running the motor to eliminate other accessories like the alternator, a/c compressor, etc. and the squeak persists. The squeak is a rythmic intermittent squeak definitely tied to engine rpm. It continues whether in park or when driving, seems worse once the engine is warmed up. Oil pressure, looking a internal dash guage, seems to be fine. I had noticed a bit of a tapping noise in the past prior to the squeak. It is definitely getting worse. Any ideas or suggestions?
Re: Squeak from engine
My engine was doing the same thing and it was the harmonic balancer.
It was spining within the hub and when there was a load such as the ac...it was worse....at fist it was intermitent then it got worse and when it went out it was bad. So I would check that first. Pull your belt off again and check it to see if the rubber bushing inside is bad.
The crankshaft balancer was a good idea, but, I had the problem and replaced it with a new one at 150,000 miles. This squeak is definitely in the engine. I have removed the serpentine belt and the squeak persists. My ASE mechanic friend tells me, the he thinks it is a bad hydraulic lifter on #3 or #5 piston. His recommendation was to first try an oil change and put in a quart of lucas oil treatment with 4 quarts of oil. Warmed the engine up good and the squeak is still there, but he thought it might take a bit for it to work into the lifter. I also checked the oil that I drained and found no metal shavings or particles in the oil.
I dunno man. Some times the oil pressure will fall with a spun bearing. Just from my experience if the squeak is loud enough to hear and your oil is good. Chances are its not a bearing. The way the motor is set up there could be harmonics coming from any where. When do you hear the squeaks
Oh yea the lucas is a personal preference some like it some don't. I would continue with normal oil. My motor has 183k on it and I have always run AC delco oil filter with castrol 10/40. My car runs just about as hard as it ever has.
Turns out that my squeak in the motor was a bad lifter and worn camshaft on the #5 cylinder. I have included a link to a photo. Put in a new Comp cam, lifters, rockerarms, timing chain and gears, etc. and it runs great.
Caps94ZODG
22
07-30-2002 08:45 AM
