Squeaking Clutch??
Squeaking Clutch??
My clutch squeaks when I push it in, but only when its cold out.
I've looked under the dash, but cant tell what it is, it sounds like metal on rubber I think?
I've tried a silicon lubricant spray, but still squeaks, and its really annoying.
How can I make it not squeak?
It is your clutch pedal, mine does it too, Its rather annoying, like you said only in the cold though. I've seen topics posted about this in the past, but never an answer for it. Anyone else know ?
Yea, I have this problem with my v6, its really an awfull sound, only when i start the car and about 20min after that, then the sound goes away. I asked someone and he said it had something to do with the springs? I really dont know.
I had the same problem but i fixed it!
i used some dura lube to give the hinges oil, its not the hydrolic metal rod thing thats squeaking.
if u take off the botom pannel or use a mirror you can see that the clutch pedal pivots on hinges just spray the hinges.
i had the problem since i bought her, i tried lubing the rod thing but i found out that it wasnt it
i hope you understand what i mean
damn i love the sound of a quiet clutch pedal...
