squealing belt or pulley?
my vehicle is squealing from either the belt or one of the pulleys, i sprayed the alternator and it still squeals so its not the alternator. Any suggestions on what i should do? the belt looks new no cracks i just got the car last week and trying to fix it up. thank you
Really, take off the belt...like was stated above.
If the noise goes away you should spin the individual components by hand to feel for any roughness or bearing 'rumble'. The power steering pump will spin but not easily, the AC compressor will spin easily enough without the clutch engaged. The alternator and the belt tensioner will spin freely. None of these things should rumble.
Once you get the belt off, start with the tensioner....in my opinion that's the most likely culprit.
However, none of them may make noise....then it's the belt. I use a gatorback and haven't had a issue for years.
I had a bit of trouble tracking down belt / pulley squeal noises last yr. I first replaced the main belt. The squealing was lower, but did not go away. Then I replace the tensioner pulley that removed 1 squeal. Apparently there was more than 1 source of squeal. I then replaced the A/C tensioner pulley which was not only squealing, but the bolt hole was ovaled out. Also, replace the A/C belt. After that the compressor broke, but that's another story.
So,
1. Tensioner
2. Belts
3. Idler pulleys
If that doesn't work, it's either the water pump or AC
So,
1. Tensioner
2. Belts
3. Idler pulleys
I saw the water pump mentioned as a potential cause for the squeak. This will be readily answered when the belt is removed...squeak remains, it isn't the belt or a belt driven accessory. The water pump isn't belt driven so it would be suspect. If the squeak goes away when the belt is removed, it can't be the water pump.....
