i have a 97 z28 pretty much stock with a squeal that gets louder when it heats up.i can't hear it when i accelerate but that doesn't say much and it still runs strong
Pull the serpentine belt and see if it goes away. This could be the alternator or A/C compressor. Also check the weep hole on the water pump, it's bearings could be shot.
i will check that as soon as i get light outside and thanks for taking the time to help me out they should just make a sticky on squeeky lt1's thanks again
alright so it's not the belt and no leaking weep hole i got underneath the car and it sounds like it is coming from where the motor hits the tranny .i made sure the bolts were tight but i still get the noise
