Standard SBC cam in LT-1 Block
#16
Originally posted by jonaddis84
As long as its a flat tappet, like mentioned above, he wont have to worry about the retainer plate...since the lobes are cut on an angle that keeps the cam from sliding out. Only other thing needed is longer pushrods
-Shannon
#17
Didn't the factory run some regular cams in roller blocks in trucks or something?
http://www.sdpc2000.com/cart.asp?act...=1622&pid=1857
This is the kit to covert them if you have a roller block already so you should be able to go back.
#19
http://www.sdpc2000.com/cart.asp?act...id=244&pid=133
I don't think I am confusing it.
You have to swap the cam with it also.
Sergio
01-27-2016 04:27 PM
stockssn2o
05-25-2015 08:54 AM
Brandon Wittmer
12-20-2014 09:51 PM
routesixtysixer
06-23-2002 02:29 PM
