starter burned up
starter burned up
all she does is click, once, when i try to start it, luckily its a manual and we could push start it
what options do i have other then an OEM replacement, i've heard about the LT4 starter being lighter, with a higher torque rating? is that true?
is there any out there that will work on the LT1 with longtube headers, that are lighter and more powerful?
might as well upgrade if i can....part numbers would be great
thanks
Steve
thanks
Steve
i just had the part # for that because while doing my mcleod clutch install i needed to replace it since the stock shims didnt leave it much room, i kno with the LT4 an the CVR starters they get in the way of the #8 primary on the LT's =/
i dont know if it died slowly or not, i was having starting issues for awhile b4 this but i chalked it up to a fuel problem, could've very well been the starter, i guess i'll find out when i get a new one!
how many teeth is the stock flywheel?
jackpawt883
09-10-2015 08:53 PM
