Steam pipe gaskets
Old 05-22-2008 | 01:03 PM
Jazsun's Avatar
Steam pipe gaskets
Do I really need new gaskets or can I re-use the old ones and put some rtv on them? They are just rubber so I find it hard to believe they would be bad from removing them once.
Old 05-22-2008 | 01:05 PM
Jazsun's Avatar
Any place I can buy them online?
Old 05-22-2008 | 01:12 PM
Stl94LT1's Avatar
I've reused mine twice, no RTV.
Old 05-22-2008 | 01:24 PM
Jazsun's Avatar
Ya I think I am going to end up doing that as well, Need to put the car back together this weekend and no dealer has them in stock.
Old 05-22-2008 | 04:33 PM
ShownomercyZ28's Avatar
GM performance, and its product # 10108689 I think
Old 05-22-2008 | 04:53 PM
SnakeOiler's Avatar
aren't they the same as the oil drain plug seal
Old 05-22-2008 | 05:21 PM
Don't think so. Does an oil drain plug seal look like this?
I have been told that NAPA 730-2922 oil cooler line gasket kit has seals that will work and it's less than $10.
Old 05-22-2008 | 08:47 PM
maverickmk's Avatar
good call - I think that's the right PN
Old 05-22-2008 | 09:14 PM
If you look at the pic in the link in my post, you would know it's the right p/n.
Old 05-23-2008 | 06:37 AM
maverickmk's Avatar
crap - I didn't even click on that, I thought it was a picture of an oil bolt gasket, but upon further review (read: actually reading) I now realize it's not.
Old 05-23-2008 | 01:18 PM
Z28blake's Avatar
Quick connect trans cooler lines on Any newer GM truck uses a gasket like that .Thats what I used.You can get them a Napa.
Old 06-04-2008 | 07:19 PM
RACEON's Avatar
You used them twice. I guess the rubber is pretty pliable and it doesnt get affected by crush when torquing them.
I just realized I need these, possibly.
Old 06-04-2008 | 11:50 PM
Jazsun's Avatar
Mine arn't leaking yet...knock on wood. And I've had the car running all over town.
KamikaZ28
05-28-2015 12:45 AM
95z_28_camaro_4_Ivan
05-08-2015 09:56 AM
carl.froehlich
03-13-2015 12:38 AM
Jazsun
12-29-2014 12:14 PM
Quick Reply: Steam pipe gaskets
