Steam Pipe Question (Not About Removing It)
Does anyone know if the steam pipe can be routed into the heater hose ports on the water pump? I changed the radiator in my S10 conversion and it does not have provisions for the steam tube and the rest of the heater hoses are currently blocked off. It was running to a Y in the upper radiator hose but the new radiator required me to use the stainless steel hose kit so the Y is out.
Yes, but the pressure is directional. As long as the line you want to tap into is going the same route then I don't think it'd be a problem. If they're going the opposite ways then you may have problems.
Jim
