Step by step cylinder head procedure
Im doing a head swap and need step by step instructions. Where would I find the most complete ones? I see bits and pieces here and there but there are so many little things to do to do it right.
HP Books "How To Rebuild Small-Block Chevy LT-1/LT-4 (sic) Engines" by Mike Mavrigan is an excellent reference - even if he did erroneously put the hyphens in LT1/LT4. ISBN: 1-55788-393-9
http://www.afrashteh.com/guide/install.htm
Everything, but the heads, can be found on my site.
I used Shbox site when I did mine, IIRC the only thing that I had to look for elsewhere were TQ numbers for the heads. Which IIRC I used the search on this site to find.
IMO a head swap on an LT1 is quite easy. Dont be intimdated
Courtesy of Alex Afrashteh:
I bought this a few years back to use when I did a rebuild but it has lots of good info for a head swap also.
Step 1. Remove Intake
Step 2. Disconnect Battery
Step 3. Remove alternator
Step 4. Remove wiring harness sensors
Step 5. Drain Liquids
Step 6. Remove Throttle body
Step 7. Remove Intake Mani
Step 8. Remove Headers
Step 9. Remove Heads
DONE.
DONE.
You should be writing the 'How To' books.
Thats like disassembling a gun before unloading it.....I usually disconnect the electrical supply first!!!!!
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
