Still cannot decide on which cam for stroker/nitrous PLEASE HELP!
Alright need to settle this for the last time and asap.
Currently i have the 230/236/112 xe with .544/.555 lift on my 1.6 rockers.
I am debating keeping that or going to the 230/242/??? xe with .544/.576 on 1.6s
Im building a 383 that will see nitrous (200 shot) later on.
I am not sure how much n/a power i will be sacrificing with the nitrous cam, or how much nitrous power i would sacrifice on the n/a cam.
those are the only 2 cams i am debating as i dont want to swap springs since the heads are setup and ready to go.
Im not sure that with the nitrous cam i would really be giving up any power n/a, but would most likely gain more power on the juice right? and if i do get the n2o cam, what lsa, i want some killer lope still but dont want to blow all the juice out the exhaust
Because you want it to be a nitrous motor, you want a big seperation between the intake and exaust lift... So for your choices, the 230/242 would be better.
A little advise, put 1.52 rr's on the intake, and 1.6's on the exaust.
how much power am i going to be losing n/a with this cam? cause thats what it is gonna be most of the time, however i also need to know what kind of power increase ill see with this cam over the other one on juice.
and why do i want lower lift on the intake? for anyone who needs to know, springs are good to 600 lift
Lt1son
12-31-2014 01:35 PM
