Still Hesitation at 1200rpms
This only happens when I am NOT under load. I don't notice a difference when accelerating quickly. At 1200 rpms when just speeding up slowly, it hesitates and loses power for a split second before picking back up. This always happens at 1100-1400 rpms and it causes my RPMs to drop by 100 rpms when this happens (I have a video if you guys want to see it).
Fuel pressure is fine
Checked intake elbow and it's fine
Re: Still Hesitation at 1200rpms
Video is right here: [URL="'s a very subtle drop, but you can see it and here a very small "rev" after the engine picks back up. Not the greatest quality, but I only had my phone.
As far as this issue goes, I found out two things:
1. When this happens, the fuel pressure is raised by 2-3psi. Doesn't say a whole lot except it is either an injector failing to fire, or a vacuum leak.
2. Another side issue that I found is when I actually took the car under load. I brought the RPMs up to 5150rpms and watched as my fuel pressure went from 34psi to about 14psi once at 5150rpms. HOWEVER, fuel pressure with the vacuum hose off reveals 42PSI of pressure. In addition, it holds pressure fine.
So, what do you guys think? The intake elbow is fine, so what else am I looking at now that is causing this stall?
Re: Hesitation at 1200rpms
The last sentence is confusing - did you test the fuel pressure with the vacuum line off ONLY at idle? Or did you also test it with the vacuum line off at 5,150rpm/WOT?
Ugg, here is the link. Don't know why it didn't work the first time. [autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=145&t ransactionid=1296304080-7194185244&posted_by=FastandBlue_camaroz28.com[/autostream]'m still trying to figure out if there is a misfire, but this raise in fuel pressure ONLY occurs when I am speeding up moderately and the car falls on its face. If I idle the car, the fuel pressure won't rise at all. So only under light load and at around 1400 RPMs will what you see in the video occur.
Yes, exactly. I was shocked, too. I did both the vacuum line off test and the under load test. Passed the vacuum test fine, but totally gave out at WOT. I can get a vid of it if you need to see it, but I can assure you that at WOT, the pressure was well below 20psi.
I'm just saying I did it the vacuum line off, then reattached it and drove it on the freeway under load. The vacuum line was on for the latter test.
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
